Tables not exporting as formatted in 0.15.9 and 0.16.3
Put the following table into a document.
|D| |E| |F♯| |G| |A| |B| |C♯| |D|
|1|W|2|W|3 |H|4|W|5|W|6|W|7 |H|8|
Rendered table (like it does in the app itself)
Outputs as text
  • Operating system: MacOS 11.6.7 (Big Sur)
  • Debug info:
    • SYSTEM INFO:
      Obsidian version: v0.16.3
      Installer version: v0.15.9
      Operating system: Darwin Kernel Version 20.6.0: Tue Apr 19 21:04:45 PDT 2022; root:xnu-7195.141.29~1/RELEASE_X86_64 20.6.0
      Catalyst license: insider
      Insider build toggle: on
      Legacy editor: off
That’s because you don’t have a space before your table.
Put an extra line break after “Example: D Major” and it should work. I tested in reading mode, and in an exported PDF, and it works.
Keep in mind that in Markdown, if you didn’t have Obsidian’s special “Strict line breaks” turned off, this wouldn’t even render as a separate line. You need that break to end the paragraph.
Example: D Major
This topic was automatically closed after 20 hours. New replies are no longer allowed.
