System/ RAM requirements for Obsidian
I was running obsidian on my laptop with Intel i3 processor and 4 GB RAM but was experiencing frequent hanging of system and not able to run any other program, not even chrome, is there a minimum system requirement for this, is it listed somewhere?
I’m not aware of any technical requirements but it would depend a lot on how many notes you have and how long they are. Right now Obsidian isn’t designed for low-spec computers and our optimizations tend to favor consuming more CPU/RAM to improve the app’s experience, which may not work as great especially if you have low RAM that may cause swapping to happen frequently.
According to an answer from a couple of years ago, it seems to be a pretty low requirement:
Again this would all depend on whether you have 10 notes, or 100 or 1000, and of course your system spec. Also “i3” basically means a “low-end” processor for Intel, but over the years the performance factors differ widely (a modern i3 is likely 2-4x faster than an i3 from 2010). Given you only have 4GB of RAM I would assume your laptop is quite old.
It may help to disable the Graph View plugin and stick to only notes if your machine is having trouble!
Hi there,
I want to reopen that thread.
I just realised, that my Obsidian has a very big RAM-usage: 700 MB.
I have around 8.000 files in my vault (not only .md, but all kind of files as Doc-Management-System).
Do you have any tipps, to lower that RAM-usage? Do I have too much plugins installed?
Obsidian version: v1.1.9
Installer version: v0.15.8
Operating system: Windows 10 Pro 10.0.19044
Legacy editor: off
Community theme: LYT Mode v1.6
Plugins installed: 40
Plugins enabled: 19
1: Dataview v0.5.55
2: Hider v1.2.4
3: Minimal Theme Settings v6.2.0
4: Advanced Tables v0.18.1
5: Vantage - Advanced search builder v1.4.2
6: Natural Language Dates v0.6.1
7: Calendar v1.5.10
8: Excalidraw v1.8.14
9: Underline v1.2.1
10: Tag Wrangler v0.5.6
11: Outliner v4.2.1
12: Image Toolkit v1.3.1
13: Tasks v1.25.0
14: Omnisearch v1.11.1
15: Excel to Markdown Table v0.4.0
16: Keyboard Analyzer v0.1.3
17: Copy as HTML v1.0.6
18: Tracker v1.10.9
19: Annotator v0.2.10
700mb is likely the baseline. You can try to disable some plugin but I don’t think you can go much lower that that.
