System Copy/Paste does not work in vim mode on linux
Open Obsidian on any KDE-flavored linux
Enable Vim mode
Select text, either with mouse or v
Copy to the system keyboard with ctrl+c
Paste anywhere
Copy to system keyboard should work even in vim mode
the selected text was not copied to the system keyboard
  • Operating system:
  • Debug info:
    Obsidian version: v1.0.3
    Installer version: v1.0.3
    Operating system: #58-Ubuntu SMP Thu Oct 13 08:03:55 UTC 2022 5.15.0-52-generic
    Catalyst license: none
    Legacy editor: off
    Plugins installed: 1
    Plugins enabled: 0
Also reported here: How to copy with vim mode? - #32 by rroa
Obsidian is awesome, y’all are the best :slight_smile:
Install obsidian-vimrc plugin. and follow instructions to create .obsidian.vimrc.
Paste the following:
set clipboard=unnamed
unmap <C-c>
iunmap <C-c>
In How to copy with vim mode? - #27 by santi only the first unmap was suggested, but the second is needed for insert mode.
Don’t forget to restart Obsidian after saving the vimrc file!
Amazing! That worked, thank you!
