- Open a vault and open a document
- Use the default theme (or most other themes as this bug effects all but two themes as far as I could find)
- Enter the following content;
\frac{1}{9}
or any other latex math.
5. Ensure you are in edit mode (reading/preview will hide the underlying syntax)
4. Ctrl+Shift+I > select element > any of the latex symbols
5. Scroll down the CSS rules until you see the following (source app.css:5707);
cm-s-obsidian .cm-inline-code, .cm-s-obsidian .cm-math {
color: var(--code-normal);
- Disable the checkbox next to
color - Observe syntax highlighting suddenly be implemented
This should be default behavior, it should not be hidden behind disabling a core CSS rule.
The CSS rule mentioned acts as a permanent disable for latex syntax highlighting.
- Operating system: Linux (PopOS, Ubuntu)
- Debug info:
Obsidian version: v1.1.9
Installer version: v1.1.9
Operating system: #202212290932~1673966427~22.04~e15d5b5 SMP PREEMPT_DYNAMIC Tue J 6.0.12-76060006-generic
Legacy editor: off
Plugins installed: 2
Plugins enabled: 2
1: Style Settings v0.4.12
2: Sortable v0.3.0
The selector in question is the latter, .cm-s-obsidian .cm-math. The issue is a selector specificity issue, as the syntax highlighting is applied directly via selectors like .cm-tag which has 0,1,0 specificity, whereas this rule has 0,2,0 specificity.
This issue can be fixed with the following diff;
// app.css:5707
-cm-s-obsidian .cm-inline-code, .cm-s-obsidian .cm-math {
+cm-s-obsidian .cm-inline-code, .cm-math {
