Syntax highlighting for code blocks in Edit mode works, but not as intended
Syntax highlighting for code blocks in Edit mode works, but not as intended. I have the Atom theme installed and in Edit mode the theme is not applied to my code blocks. Instead I get the most obnoxious ‘theme’ ever.
The Atom theme is only applied to Read mode.
I also noticed that the theme I’m only seeing in the Edit mode, is the one used by the default theme.
I think this might have to do with some CSS rules that are absent in the Atom theme.
Any help is greatly appreciated!
Demo screenshots:
Edit mode
Read mode
I also noticed that some other random theme, like Minimal, does not show the built-in syntax highlighting theme, so my theory could be correct.
Edit mode
Read mode
This post might have to do with this problem.
Have a look through this one as well:
I don’t think that post has anything to do with my problem. Thanks anyway.
I fixed the problem by reinstalling the theme, in my case the Atom theme :tada:
I’ve been having this issue for so long… I’m finally able to read code snippets without losing my mind over the ‘beautiful’ default color set :laughing:
Edit mode
Reading mode
Yes different issues but highlights the use of two different PS tools and themes for the different display modes.
