After Sync of Obsidian ( V1.8.4) the canvas is stuck in Data View edit mode. It does seem to be updating after the sync as far as new cards go but still stuck in data view mode
I have tried to push another sync
Have done some research with no leads
uninstalled Obsidian on remote computer and resynced
What do you mean with “data view edit mode” ? Dataview doesn’t have any special edit mode. If you got some querying causing stuff to hang at your end, I suggest disabling the Dataview, switch to source mode on whatever notes are open, and see if you got a too open query trying to read every file and then some from your vault.
Thank you for your help, it turns out that all the plugins do not sync so i had to make sure both versions were up to the same version as well as the same settings. Thanks again
