Sync settings for Fonts and Snippets... just one switch?
I am using Obsidian Sync to keep my Windows PC and iPhone and iPAD in sync. And I am using different fonts on the Windows machine and on the iDevices. Therefore I had switched off the “Appearance settings” in “Vault configuration sync”.
Now I have started working with CSS-Snippets. And I had to learn that I do need to turn this switch on, in order to sync the CSS-files to the iDevices (plus using the switch “Themes and snippets”).
Am I right that there is just this one switch to control the sync of fonts AND snippets?
Best, Wolfgang
CSS snippets are synced via the Themes and snippets toggle, not the Appearance one so you should be good.
These are my settings – snippets sync fine between devices but what’s set as a theme, font, enabled snippets, etc., don’t. Give that a try.
Enable the snippet files you want active on each device once and you’re good to go. Any changes you make to those files on desktop will be synced over to the mobile devices.
Thank you :grinning_face:
