Sync icon rotation wobbles on mobile
On mobile:
  1. Enable Sync.
  2. Connect to a remote vault.
  3. For convenience, pin the right sidebar.
  4. Type something and watch the Sync icon.
I didn’t literally follow the guide but I tested in a vault started in restricted mode, no snippets and default theme.
Icon rotates smoothly.
Icon wobbles, wandering slightly as it rotates.
https://cdn.discordapp.com/attachments/900870622631063552/1164347053858627655/RPReplay_Final1697672269.mov?ex=6542e1b2&is=65306cb2&hm=eee7d6743eee82fd464b8dec854e2ebabe3b75f7cfa2b96c8479804fdbedd37f&
Operating system: ios 17.0.3 (Apple iPad)
Obsidian version: 1.4.16 (114)
API version: v1.4.16
Catalyst license: none
Legacy editor: off
Discord discussion confirming the wobble isn’t intentional: Discord
In my main vault I use a snippet to make the Sync icon always visible: [Mobile] Make Sync icon always visible - #25 by CawlinTeffid (but I confirmed in a testing vault that doesn’t have that snippet).
thanks
will be fixed in mobile v1.5. no etas.
