I’m using Obsidian for quite some time and im absolutely loving it! However, i have serious issues with syncing. I actively use 3 devices, two PCs with Ubuntu on them and one Android phone. I tried multiple times to find a way to sync my vault between those devices but i failed.
I tried setting up Syncthing but it simply didn’t work. There’s always issue with some files that end up being out of sync and everything stops working.
Using git looks very complicated to me, not the technology itself, but the idea of having to pull/push changes constantly and conflict is always a thing that can happen
I’m also not that fond of idea to use Google Drive because i don’t want to connect my google account to my work laptop
Obsidian sync, to me, is too expensive
Did anyone successfully set up sync any other way for ubuntu and android?
Instead of file-based sync, it syncs only the modified differences, so if you have two desktops next to each other, updates are reflected instantly.
It also handles conflicts and intelligently merges when multiple changes are made simultaneously.
