So there’s a bug in settings in the iOS mobile version, where if you “slide back” with your thumb from a subpage then it “jumps down” a bit. If you press (<-) back button it works right. This is just for the “slide from edge” in settings. This happens with the built in settings. Try Files and links, scroll down to Advanced, click “Excluded files”. When you swipe back left “from the side”, the entire settings view in Files and links jumps down a bit. If you instead click (<-) it stays in place. This makes it hard to navigate in settings
Did you read and follow the Troubleshooting Guide ? [Yes/No]
When returning from subpage in settings i expect position to not jump
It jumps
Tried in iOS 13 and 14
