Using the core Template plugin, whenever I manually insert a template, it automatically adds a newline at the end of the inserted string. Is there any way to change this behavior, ideally on a per-template basis, either with the core plugin or the Templater community plugin? It makes using Templates for inserting text snippets in a sentence cumbersome.
Everything I search for finds issues about Templater inserting newlines at the start of files, which is not the plugin or issue I am dealing with.
