I have a list of YAML Metadata
pages: startpage - endpage
of different chapters of a book I am working with.
My aim is, to
show startpage and endpage in a tableview
build the sum of theses pages in a third row
show the total amount of pages below.
Here is my code:
pages:
- 1 - 101
- 101 - 150
- 151 - 240
```dataview
TABLE WITHOUT ID
split(pages, "-")[0] AS Startpage,
split(pages, "-")[1] AS Endpage,
number(pages) AS Summe
FROM "currentfile"
FLATTEN pages
WHERE file.name = this.file.name
TOTAL: =round(sum(number(this.pages)), 2)
It tried to use split() but the result is a datatype text instead of number. With datatype text I can only use it for the first and second row but not for building the amount of pages.
I can get the startpage by using number() as a datatype number but it is working only for the startpage as first number.
I cannot extract the second number behind the - .
The combination of number(split()) is not working.
My way to handle this is to build a query doing all but the sum line, and then do that query within a dataviewjs query to calculate the sum.
So try the following in a file of its own, and see if you can’t adapt some of it to your liking.
pages:
- 1 - 101
- 101 - 150
- 151 - 240
## Original query
```dataview
TABLE WITHOUT ID
FLATTEN pages
## Chapter query
```dataview
TABLE WITHOUT ID start, end, number(end - start) as total
FLATTEN pages as chapter
FLATTEN list(split(chapter, "-")) as p
FLATTEN number(p[0]) as start
FLATTEN number(p[1]) as end
## With total sum
```dataviewjs
const result = await dv.query(`
if (result.successful) {
const total = result.value
.values
.map(c => c[2])
.reduce((acc, val) => acc + val, 0)
result.value.values.push(["", "<span style='float: right'><strong>Total:</strong></span>", total])
dv.table(result.value.headers,
result.value.values)
} else
dv.paragraph(`~~~~${ result.error }~~~~`)
