Struggling with bottom-border for nested lists
I am playing a bit with custom-css to make my nested lists behave like I want them to behave.
So I have the following example list:
- Row 1
	- Row 1.1
	- Row 1.2
	- Row 1.3
- Row 2
	- Row 2.1
	- Row 2.2
		- Row 2.2.1
		- Row 2.2.2
- Row 3
- Row 4
I want to customize the CSS, so Row 1, Row 2, Row 3 and Row 4 all are bold and have a border-bottom, like in the example image (red is just for illustration):
However, when I try to format it using my custom-css it works for Row 3 and Row 4, but for Row 1 and Row2 it does not work (as in the picture below).
I understand why this is happening: The border-bottom for the li tag for those two elements is logically under Row 1.3 and Row 2.2.2, because they have nested ul and li elements. However I have no clue on how to resolve this (I am not a CSS expert, just learned about CSS selections yesterday :slight_smile: )
The custom.css I have used is the following:
/* get rid of the bullet infront of level 1 */
div.el-ul > ul > li > span.list-bullet {
    font-size: 0px;
    list-style-type: none;
    padding: 0;
    margin: 0;
/* create line under level one li */
div.el-ul > ul > li {
    font-weight: var(--font-bold);
    border-bottom-style: solid;
    border-bottom-width: 2px;
/* reset the level 2+ li elements */
div.el-ul > ul > li > ul li {
    font-weight: var(--font-normal);
    border-bottom: none;
So I have three questions - which you can hopefully help me with by guiding me towards the right direction (or have the answer available :wink: )
  1. Any tips on how to fix this nesting issue in the CSS, so I can get the bottom borders underneath the Row 1, Row … , Row 4?
  2. This is for reading mode only. How do I apply the same in Preview Editing mode? Will that be the cm-list-1 class to update the css for?
  3. Can I apply the same formatting as for heading 1 by referencing it in css somehow?
thanks a million
Have you managed to figure things out?
:not(li, ul) > ul > li::before {
    content: "";
    height: calc(1em * var(--line-height-tight));
    width: 100%;
    position: absolute;
    left: 0;
    border-bottom: solid 1px red;
To explain, the selectors reference each li that is a direct child of a ul that is not the direct child of a ul or li. It then selects that element’s ::before pseudo-element, and gives it content, so that it renders. Position is set to absolute to remove collision for the pseudo-element. The height is simply a guess (it looks good on my screen), but uses the Obsidian line-height variable, so I think it should work for you.
Hope that helps, and if you’re interested in learning more about css, I’d suggest checking out mozilla’s developer resources.
