Steward - plugin for AI-powered search, vault management, and automation workflows
Disclaimer
Community Directory: Link
Hello everyone :waving_hand:, my plugin, Steward, is now listed on Obsidian community plugin!
Steward is yet another AI-powered assistant that helps with search, vault management, and automation.
Start with a slash
Type / at the beginning of any empty line in your editor, or open the chat interface. Type your request and press Enter.
Type / ? for available commands. Press Shift+Enter for a new line. Type m: to switch models. The chat adapts to your theme and works in both editor and reading view.
Search anything
Built-in very fast search engine. Search by tags, properties, keywords, or file names. Uses TF-IDF scoring with typo tolerance. Results are paginated and scored by relevance.
Stw-Demo-Search-light
Manage your vault
Create, update, delete, copy, and move files through simple commands. These operations work on artifacts created from previous steps. If artifacts are created locally, they remain local during operations.
Update directly in the editor:
Update-In-Editor
Update the selection:
Stw-Demo-Update-selected-text
Generate media
Generate images and audio directly in your vault.
Read only what you need
Read specific sections, not entire notes. If you query: “read the table above” then Steward reads only the table above your cursor, not the entire note.
Build your own commands
Create custom commands that combine multiple actions into reusable workflows.
In-note definitions: Write commands as YAML blocks in the Steward/Commands folder. Define what they do, which commands to run, and how to use them.
LLM-assisted creation: Share your idea in plain language, and Steward helps create the command structure.
Fine-turn your command with customizing system prompts and excluding tools.
Automated workflows: Commands trigger automatically when files are created in specific folders, when notes are tagged certain ways, or when content matches patterns. Turn your vault into a self-organizing system.
Create User-defined command with LLM’s help:
User-Defined-command-creation
Automated command:
Steward-Demo-Auto-trigger
Other features
Model fallback: Automatically switches to backup models when one fails or times out.
Intent classification: Uses embeddings to learn from queries. Similar requests are cached for faster responses and fewer tokens.
Fast startup: Lazy-loaded services mean quick startup even with large vaults. Internal services initialize only when needed.
Get started
Install from Obsidian Community Plugins, configure API keys, and start typing / . Works with OpenAI, Gemini, DeepSeek, Ollama, and other popular models.
NOTE: This is the first version of Steward. Bugs are expected, and contributions are welcome!
Check my repo: Steward
Hi haidang009,
Thank you for sharing your new Obsidian Plugin
Ultimate AI recommended that I try out Steward
Using setup below:
BaseURL: https://chat.obsidianaitools.com/v1
OpenAI Key: Obtain from obsidianaitools.com Settings → Account
ChatModel: openai: (eg: openai:gpt-5-1)
refer: API Models & Usage for popular model IDs.
Embedding: openai:text-embedding-3-small
Speech: OpenAI Speech TTS-1 HD
Image: openai:gemini-2.5-flash-image
Few things I wanted to clarify with you;
  1. I noticed when the Slash Command Core Plugin is enabled that this conflicts with your plugin, is this by design or should Slash Commands be disabled? Was the goal of Steward to replace the slash command core plugin functionailty?
  2. When opening Steward Chat in the right pane, how do you reference the current open note?
  3. The Steward Chat inside the current note body appears to make edits in its own Steward Markdown Convesation note, was the goal here to create the modified note based on the current note and then open that note to make changes to the original note?
  4. You mention “Welcome to your always-available Steward chat. Type below to interact or type / ? to see available commands.” when you type /? it doesn’t do anything. Is this by design or am I doing something wrong?
  5. Search doesn’t always pick up notes within the vault. Is there a more refined way of doing it?
Overall it’s a good start. I’m know that you have put a lot of hard work into this plugin. I can see a bit of the Smart Second Brain Plugin mixed with BMO Chatbot
Hi Paul, the commands should be at a space after the /
So /[SPACE]? works..
When i want to interact with AI I type: /[SPACE]question TEXT OF MY QUESTION (In lowercase)
Cheers
Ray
Hi @PaulDickson, sorry for responding late.
Here is my response to your questions:
  1. The core Slash Command doesn’t conflict with Steward. When the Slash Command is enabled, Steward autocomplete will be disabled.
  2. You can refer to a note by entering the note name in the input.
  3. Yes, the modified version will be first rendered in the Conversation note, and then ask the user to confirm the changes. After confirmation, it will replace the original.
  4. You missed a space after the slash: /{space}{your query}
  5. The search is relevant. It calculates how keywords are relevant to a note. The reason why it doesn’t pick up notes is various. If you think it completely doesn’t work, please create an issue on the repo so I can take a look.
PS: Version 2 of Steward has just been released. It has better context awareness and complex task handling. Please take a look.
Thank you.
Hello everyone, I’m Dang, and my plugin, Steward, is now released in version 2!
Here are the major changes:
Autonomous agent
We migrated from an extraction-based system that processed tasks sequentially to a fully autonomous agent architecture. The new system uses a single primary agent (SuperAgent) that intelligently activates and uses tools to accomplish tasks. This makes Steward more capable and efficient at handling complex workflows.
Data awareness agent
Added DataAwarenessAgent for tasks that require input awareness and processing large numbers of files. The SuperAgent can delegate these specialized tasks to the DataAwarenessAgent, which processes files in batches to avoid token limits while maintaining context awareness.
Custom provider support
You can now add custom LLM providers directly from the settings. This allows you to use any OpenAI, Google, DeepSeek, etc, compatible API endpoints with your own configuration.
User-defined command improvements
Version 2 is now the default version for user-defined commands. For commands with multiple steps, the system uses a to-do list to track each step and provide additional data such as system prompts and models. You can also use a one-step command with a complex query and let Steward decide the steps automatically. The command definition has been simplified by removing system modification and tool exclusion options.
Showcases
Reasoning
Steward-Demo-Reasoning-2
To-do list and revert changes
Steward-Demo-Todo-list-and-revert
Complex task
Steward-Demo-Read-and-summarize
Check out my repo: https://github.com/googlicius/obsidian-steward
Cheers,
Dang
Hi haidang009
Thank you for your detailed response.
I will keep your plugin on my radar and revisit as it evolves.
Regards,
Paul
Thanks for sharing. I’ll take a look.
Steward Update: Introducing Agent Skills and early conclusion
  1. Agent Skills :brain:
    Steward now supports the Agent Skills specification, allowing you to extend its domain-specific knowledge. You can see details here: Skills · googlicius/obsidian-steward Wiki · GitHub
  2. Early conclusion :high_voltage:
    With new tool Conclude, Steward now wraps up the conversations more effieciently by eliminating the final turn, which is the most token-consuming step just used for conclusion.
Link repo: Obsidian Steward
Wiki: Steward Wiki
Here is the demonstration Obsidian bases skill:
Skills
Steward 2.2.0 is here!
Hi everyone! Steward — the AI agent for Obsidian — just got a nice update. Here’s what’s new:
Search improvements
You can now use comparison operators (==, !=, >, <, >=, <=) and relative date expressions (like today, yesterday, last week) in search. For example:
/search Notes with priority greater than 3
/search Notes where rating is at least 4
/search Notes are created last week
/search Tasks with status not equal to "done"
/search Tasks are still within due date
Steward-Demo-Search-operators
Tool call content streaming
When Steward runs tools, you’ll now see their output streamed into the chat instead of just a loading indicator. You can follow what’s happening in real time.
Command syntax (direct tool calls)
You can now run tools directly without an AI round trip. Use the c: prefix to invoke tools by name, for example: c:read --blocks=1 or c:search --keywords=meeting,notes.
This syntax is powerful but can be a bit tricky at first. If you want to use it (especially in User-Defined Commands), check out the User-Defined Command skill — it explains the syntax, available tools, and flags in one place:
User-Defined Command Skill
It covers c:read, c:search, c:delete, c:list, c:move, c:rename, c:grep, and more, so you can build deterministic workflows with confidence.
That’s it! Enjoy the new release. Feedback is always welcome.
Steward update: 2.7.2 - Shell commands and terminals
I have released a new version of Steward; now you can run shell commands or open terminals in conversations without leaving Obisidian.
It has 2 modes: transcript - Output streamed directly into the conversation note, and interactive - For programs that require TTY (Real terminal)
Note: To open interactive programs like vim, CLI-agents, etc, you need to install the note-pty runtime, it is a library that allocates a pseudo-terminal and runs a process attached to it. I have prepared 2 scripts in the Steward folder, so you can run it directly in the transcript mode.
My repo: Obsidian Steward. CLI document: CLI wiki
Showcases:
Run transcript commands like “cd”, “ls”, etc. And install node-pty runtime from the current transcript session:
Steward-Demo-CLI-2
Open my CLI-based agent:
Screen Recording 2026-04-23 032336
Hello everyone, I’ve just released Steward 2.10.0
Steward-Demo-Tetris
New features:
- Added a new tool that allows you to write games, animations, visualizations, software, etc., directly within Obsidian. Supports HTML and SVG formats.
- Memory: Added structured memory, currently the instruction tool, to help Steward remember how it used the tool previously (in addition to the available instructions).
- Artifact: Added an artifact feature - saving “Items” that Steward creates (files with the .art extension). You can now save widgets to the Artifact folder.
Other updates:
- File reading: The read tool can now read all text files. Added line numbers to the beginning of each line to help the model update from line to line instead of counting itself.
- Image reading: If the model doesn’t support image reading, it will notify Steward instead of the user.
Links:
https://community.obsidian.md/plugins/steward
