Status bar sync icon stuck on syncing state
Fully sync your vault via Obsidian Sync
Yes
Sync indicator on status bar shows a check icon.
It still shows syncing icon, even though it says “fully synced” when hovered.
Obsidian version: v1.8.0
Installer version: v1.7.5
Operating system: Darwin Kernel Version 24.1.0: Thu Oct 10 21:05:14 PDT 2024; root:xnu-11215.41.3~2/RELEASE_ARM64_T8103 24.1.0
Catalyst license: insider
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
I have the same problem on macOS with Obsidian 1.7.7
In my setup this behavior is triggered by this plugin: GitHub - xRyul/obsidian-image-converter: ⚡️ Convert, compress, resize, annotate, markup, draw, crop, rotate, flip, align images directly in Obsidian. Drag-resize, rename with variables, batch process. WEBP, JPG, PNG, HEIC, TIF.
When I disable it everything goes back to normal.
can you post a screenshot of your sync logs?
Oh, that solved it.
I couldn’t know how to test sync with sandbox vault, so I tested with default template. I’m sorry @WhiteNoise .
I see that you already opened a github issue, thank you.
Just wanted to say sorry for all the trouble. It was excessive logging in the console due to incorrect timings for the cache cleanup, it’s been fixed now Release 1.2.19 · xRyul/obsidian-image-converter · GitHub
