Starting Obsidian stalls at loading vault / loading cache
After removing files from the vault, in my case a few thousand images and videos in multiple formats, Obsidian stalls either at ‘loading vault’ or at ‘loading cache’.
The “fix” is to
rm -rf ~/Library/Application\ Support/obsidian/Cache/Cache_Data/*
rm -rf ~/Library/Application\ Support/obsidian/IndexedDB/*
I’ve currently installed the minimal theme and its plugin, but the issue also occurred before I installed both. I’m currently cleaning up a lot of old stuff and so far had to remove cache and index four or five times.
Should this “fix” be part of the troubleshooting guide?
Successful initialisation.
Unsuccessful initialisation.
Obsidian version: v1.10.6
Installer version: v1.10.3
Operating system: Darwin Kernel Version 24.6.0: Wed Oct 15 21:08:19 PDT 2025; root:xnu-11417.140.69.703.14~1/RELEASE_ARM64_T8103 24.6.0
Community theme: Minimal v8.0.4
Plugins installed: 1
Plugins enabled: 1
1: Minimal Theme Settings v8.1.1
The system is in lockdown mode.
“Show all files” setting is off.
I was unable to reproduce with the sandbox vault, but that vault is tiny compared to my working vault. There are almost 8,000 markdown files and according to `fd -t f --exclude “.md" --exclude ".mdown” | wc -l` about 90,000 non-markdown files.
See if this happens when you disable (or exclude obsidian from) lockdown mode.
