- In a sandbox vault,
Toggle stacked tabsand open 2 tabs. Notice that changing between them is an animation. - Write a snippet
_kill-anim.csswith contents:
transition: var(--anim-duration-none) !important;
- Enable the snippet
- Test all animations, sidebars, stacked tabs, etc.
Y
Stacked tabs should transition immediately with this snippet enabled. There should be no animation.
All elements other than stacked tabs transition immediately with this snippet.
The speed of the stacked tabs animation remains unchanged.
Obsidian version: v1.6.7
Installer version: v1.4.16
Operating system: Darwin Kernel Version 23.5.0: Wed May 1 20:16:51 PDT 2024; root:xnu-10063.121.3~5/RELEASE_ARM64_T8103 23.5.0
Catalyst license: supporter
Insider build toggle: on
Snippets enabled: 1
It is not accessible to have animations that cannot be disabled.
