SQL Syntax Highlighting
  • Create new file
  • Insert a SQL code block as below
declare a_variable varchar(10) = 'E:\'
select a_variable
  • Note that syntax highlighting fails after the backslash
Y (confirmed in Sandbox vault)
Correct syntax highlighting (T-SQL does not use a backslash as an escape symbol)
Incorrect syntax highlighting
(Sandbox)
Obsidian version: v1.3.4
Installer version: v1.1.16
Operating system: Windows 10 Enterprise 10.0.22621
Legacy editor: off
Is this in editing view or reading view? Syntax highlighting is different between the views.
It fails differently in both Editing and Reading mode. In Edit mode it formats the rest of the file as a string. In Reading mode it only formats part of the file as a string and then (for no reason that I can see) switches back to proper syntax highlighting.
we use different parsers. Nothing we can do about it, just wait for the upstream fix.
In terms of the upstream fix, is that something I can follow up on and report to the upstream developers?
I’m happy to go report the bug wherever necessary.
