Hi, my Windows 10’s language is Finnish. AFAIK, Obsidian does not have a dictionary for Finnish. At least Finnish does not appear in the list of available spell check languages (the one that opens when clicking the + dropdown list). However, Obsidian sets a default spell check language, determined from the operating system’s language, so it becomes Finnish even when it’s not supported.
kuva
  1. Have an operating system with language other than the ones supported by the spellchecker.
  2. Go to Editor settings and look at Spellcheck languages. The system language is selected by default, if you haven’t changed it.
If the system language is not available in spellcheck, use English instead as a default language.
The actual result can be seen in the screenshot above. This is not a big problem for me as I know Finnish is not supported. However, for some users it might be confusing to see their language selected by default, it might give a false impression that their language would be supported by the spellchecker.
  • Debug info:
    Obsidian version: v0.13.23
    Installer version: v0.13.23
    Operating system: Windows 10 Home 10.0.19044
    Catalyst license: none
    Legacy editor: off
    Safe mode: off
    Plugins installed: 0
    Plugins enabled: 0
