Spellcheck bugged out after modifying Custom Dictionary.txt
This section assumes that your secondary mouse button is the right one, which is the default on most systems. It also assumes you’re using Windows. If not, the file paths may be different.
  1. In a fresh Obsidian Vault (sandbox is fine), open a new file and type something incorrectly.
  2. Right click the red underline and add the word to the custom (user defined words) dictionary.
  3. Go to User/AppData/Roaming/obsidian, and delete the file ‘Custom Dictionary.txt’.
I am not sure what this path is on macOS / Linux, but it is the central application storage. It’s the same directory the Sandbox Vault gets placed in.
yep!
The words defined as ‘correct’ previously would be no longer part of the user dictionary, and would be marked incorrect.
The words defined as ‘correct’ don’t show up in the custom words list (Settings → Editor → Spellcheck → ‘Gear’ icon), but are also not underlined (corrected). When typing a slightly different version of them, it shows the original under the suggestions.
Obsidian version: v1.6.7
Installer version: v1.6.7
Operating system: Windows 11 Home 10.0.22631
I have tried:
  • restarting obsidian
  • restarting computer
  • reinstalling obsidian
  • trying in sandbox vault
More info:
  • this is a global issue; the attempts at reproduction between my normal vault and sandbox vault are synced
  • the issue is that i’m stuck with these words not being defined as correct but being treated as correct
Thanks for helping!
Update: The issue was resolved. The words list is stored in an additional file:
C:\Users\Owner\AppData\Roaming\Microsoft\Spelling\neutral\default.dic
I found it in another thread (special thanks to user @Digger for the help!) → Dictionary - where is it?
Best,
TheLocalTemp
