Speechify for Obsidian: hear a note read aloud with the spoken sentence and word highlighted
Disclaimer
Is this plugin open source? Yes (MIT)
Is this plugin completely free? No. The plugin is free, but it needs a Speechify API key and Speechify bills per character sent.
Is this plugin vibe-coded beyond the author’s ability to comprehend how it works? No.
Community Directory: Link
I work at Speechify and we’ve built an official Obsidian plugin. It reads the open note in a Speechify voice and highlights the sentence being read in the note, with the word being spoken highlighted inside it. You can keep editing while it reads. Type a paragraph above the playhead and the highlight moves with the text.
Press play from the header icon, the ribbon, or a right-click in the editor (Listen from here, Listen to selection). A small bar appears at the bottom with play and pause, back and forward 10 seconds, speed from 0.75x to 3x, and a voice picker. While it plays you can click any sentence to jump to it, in the editor or in Reading view. Every action is a command, so you can give it a hotkey.
What it reads: headings, paragraphs, lists, quotes, callouts, footnotes and tables. Links are read as their text and tags as their name. It skips properties, code blocks, math, comments, embeds and bare URLs. Nothing is ever spoken that isn’t in the note.
What you need to know before installing:
  • It needs a Speechify API key from platform.speechify.ai, and Speechify bills per character sent. The plugin only sends the passages you actually listen to, a few hundred characters ahead of the playhead, so stopping after one sentence costs about one sentence. Audio is cached on your device (outside the vault, so it doesn’t sync), and hearing a passage again is free.
  • The key is stored in Obsidian’s keychain, never in the vault. The plugin’s own settings file only holds the name you gave the secret.
  • Desktop only for now, Obsidian 1.11.4 or later. Nothing in it needs desktop, it just hasn’t been tested on a phone yet.
  • Highlights work in Live Preview, Source mode and Reading view. In Live Preview, callouts and tables are drawn as widgets, so the highlight doesn’t show inside them unless your cursor is there.
Install it from Settings, Community plugins, search “Speechify”.
Repo and README: GitHub - Speechify-AI/obsidian: Obsidian plugin that reads a note aloud in a Speechify voice and highlights each sentence and word as it is spoken · GitHub
If something doesn’t read right, or doesn’t read at all, open an issue on the repo. The last release came out of a support question about tables, so those reports do turn into fixes. I’ll post updates in this thread.
Speechify gives you 500K characters free per month. That’s 10-12 hours of free audio.
