Space for Block Math equation source is not removed in lists
a minimalist reproducible content:
$\text{Some mathjax code (no matter what)}$ must be called before the following example.
- the root node of list that I wish to collapse
	- blablabla... the equation is:
	$$ E = mc^2 $$
	- then we can solve it ...blablabla
yes. plugins off. snippets off. reproducible in sandbox.
four lines of text or formula, that I can collapse in preview mode
an empty line appears right above the formula line in preview mode
you might think that this is an unimportant minor problem, but with a long list mixed / interlaced with $$ ... $$ math blocks, the mathjax rendering will result in many empty lines interrupting your reading
BTW, those empty lines are gone in reading mode, but I’d prefer preview mode for convenience
BTW 2, if it’s not list, then plain text won’t render into extra empty lines in preview mode, as long as it’s not indented
actually, I’ve found a work around : unindent the $$ ... $$ math blocks, then there’ll be no empty line right above the formula
but then there comes the caveats:
  • when I click the root node of list, only the first sub-list item will be collapsed
  • a piece of mathjax code (no matter what) must be called before (be it $$ ... $$ block or $ ... $ inline, but the line must start with $), otherwise, not only the formula line couldn’t be recognized and collapsed, but also the text line after that couldn’t be rendered into bullets
Obsidian version: v1.6.7
Installer version: v1.6.7
Operating system: Windows 10 Home 10.0.19045
Base theme: light
Snippets enabled: 1
Plugins installed: 19
Plugins enabled: 0
Some more words:
As I said (in BTW 2), since the $$ ... $$ math block’s behaviour is different in list vs. in unindented plain text (see example below), I assume that the way it’s rendered in plain text is correct while it’s bugged in lists.
line 1
$$ \text{line 2} $$
line 3
Then there's no extra empty line appearing between line 1 and line 2 in preview mode.
Thank. Renamed and added video for clarity
Obsidian_UWiUY7L3Sm
The workaround with unindenting the MathJax blocks works but it feels like a clunky solution. Especially since the collapsing feature doesn’t behave properly afterward, and it messes with the list formatting. Honestly, I’d love to see this get patched in a future update.
