Sorting by a frontmatter property which is defined as text, but contains only numbers, will have the leading zero (maybe multiple zeros) removed during sorting. The field is still correctly displayed, but the sort order is broken.
Did you read and follow the Troubleshooting Guide ? [Yes]
If creating items, in my case, a BoxID property which is a hexadecimal number - but stored as text. 01 should proceed 0A. 03 should also proceed 0A.
01 will appear after 0A, as if it is sorted as “1”. 03 will appear after 2F as if it is sorted as “3”.
Obsidian version: 1.13.7
Installer version: 1.13.7
Operating system: #5 SMP PREEMPT_DYNAMIC Sun Mar 29 21:34:09 BST 2026 6.6.130
Language: en-GB
Community theme: Storm 1.0.0
Snippets enabled: 5
Plugins installed: 10
Plugins enabled: 9
1: Homepage v4.4.4
2: Tag Wrangler v0.6.4
3: Templater v2.20.6
4: TagFolder v0.18.19
5: Commander v0.5.7
6: Tasks v8.3.0
7: Advanced Tables v0.23.2
8: Kanban v2.0.51
9: Links v1.17.51
Distro Name: Fedora
Distro Version: 44
Desktop Environment: Sway
Installation method used: Flatpak
