Songwriting Database Vault Help
Hey all! I’m trying to build a Songwriting Database that helps me organize & interact with my Lyric Fragments, Song Ideas, Songs in Progress, and Completed Songs. One thing I’m trying to do is use AI to help find theme, mood, semantic, etc connections between lyric fragments.
I put together a doc that lists out all of the things i’m looking to do and have been trying to use ChatGPT to help me build it. Some things have worked, but i am hitting a wall. Well, ChatGPT is hitting a wall. Specifically when trying to create a button within the ‘lyric fragment’ template that, once pushed, analyzes the lyrics (using OpenAI API key), then populating the properties in that template with the right info.
For button making, see the community plugin Meta Bind (I’ve never used it myself, so can’t advise).
