Hi - I’m trying to create a dataview using blacksmithgu’s Dataview plugin that will allow me to create a list of something in multiple files, and in another I can retrieve the lists from all files.
Ex…
In file A I have
Command:: pwd
Description:: Show’s current directory
Command:: ls
Description:: Lists files/folders in current directory
Command:: cd
Description:: Navigate to a folder
Use:: cd /home/user/Documents
In file B I will have more of these as I’m learning and so on
And in File C I have
TABLE
command as Command,
description as Description,
Use as Use
FROM "Work 2.0/Education/RedHat"
FLATTEN rows as R
SORT R.Command ASC
WHERE contains(Command, "")
This displays mostly correctly, however as there is three entries for File A it combines them under File A, and the Use of cd is centralised and appears in my table as if it’s connected to ls (you can view the output as I’m seeing at Screenshot-2023-03-02-at-12-59-36 hosted at ImgBB — ImgBB)
My question is - how can I split these so each Command:: Description:: Tag is on different lines, or can I not?
If not, how can I best go about achieving what I’m trying to?
If you search the forum you’ll see loads of mention as to how your fields as related to page scope, so that all the values are collated into field lists. To counter this you need to move your fields into list items. In other word you need to change your syntax to something like
- [command:: pwd] — [description:: Shows current directory]
- [command:: cd] — [description:: Navigate to a folder]
- [use:: cd /home/user/Documents]
This will allow for queries like:
```dataview
TABLE cmd.command as Command, cmd.description as Description
FLATTEN file.lists as cmd
WHERE cmd.command
SORT cmd.command ASC
A little unsure, as I didn’t test this, whether you should include the use field on the line, or whether you should grab that from the children list… It’s a little depending on use case, and how you’d like to visually present stuff.
The main thing, is that you need to use fields within a list (or task) scope to properly group them together as part of the same structure. And use that as the base of your workflow.
Note that the lists doesn’t need to be kept together in the file, you can have the commands scattered throughout the file, but each of them need to be in a bullet point of its own.
