Smoother auto-complete window for tags
Important Note
Popularity of a Feature Request is one of the factors we consider when we decide which new features to implement. Therefore, we strongly recommend you to search the forum with possible keywords.
If your request is very similar to an existing one, like it (:heart:) and make a meaningful comment, rather than creating a new thread. It also keeps the forum sane! If you find duplicate threads, feel free to send the moderators a message.
Feature requests for the Obsidian Developer API go here
Feature requests for Obsidian Importer go here
Feature requests for Obsidian Web Clipper go here
Feature requests for Obsidian Maps go here
Once you are done reading, please delete the above notes
When I type # in the editor, I’m often met with a delay while it loads up all the known tags to display in the auto-complete window. This interrupts my typing not only when I’m trying to insert a tag, but also when I’m inserting a header, and I don’t even want it to search for known tags.
I’d propose decoupling the auto-complete from the editor so it can continue doing the search in the background while the user can still type. I might also suggest not starting the search until the user has either typed at least one character, or a short delay if they’ve only typed #, so that tags don’t pop up when inserting a header. I’m not sure if the slowness is just my vault, or if this is a more common experience, but it seems like a good solution to have regardless.
It’s easy enough to wait for, just a little annoying.
I don’t notice a delay on my end (iOS and macOS m1pro chip). It may be dependent on number of tags, community plugins active, hardware, etc.
As a test, can you try in restricted mode to see if there’s a difference for the slow loading? The rest of the troubleshooting steps are here. I’d try those and report back.
Are you on Android? I’ve started to notice it more and more lately. like last couple of months. Probably since “Android: Long-pressing items in sidebar views / tabs more than once makes the app freeze”. (I’m not linking cause may not be related to WebView, but I would like to know if it could be)
In this case, I’m on Linux, specifically a Debian offshoot
I relaunched in restricted mode, and that seemed to fix the issue, so guessing this is probably due to some plugin. I’ll close the bug
