Obsidian version: 1.13.4
Installer version: 1.12.7
Language: ru
Obsidian version: 1.12.7
and for some reason, version 1.13.4, when running DevToo - perfomance - Record, does not show a screenshot of the exact moment of the action change. For example, I opened the Settings - Editor. Close record. and in version 1.12.7 it shows.
In version 1.13.4 every click on Settings categories causes 300–500ms processing delay. Downgrading to 1.12.7 removes the issue; the same interactions take ~30–60ms.
- In Obsidian 1.13.x DevTools Performance recording does not capture screenshots during interactions, while the same recording in Obsidian 1.12.7 shows screenshots correctly.
- Also hover states in Settings navigation feel delayed: moving the mouse over items does not immediately update highlighting; it updates only after click.
I’ve reinstalled Obsidian multiple times. The issue persists in version 1.13.4 but is not observed in 1.12.7.
2. Screen recordings
I reproduced the issue in a clean Hyper-V Windows environment, using a separate test vault without third-party plugins, custom themes, or personal data.
I used this environment instead of the built-in Sandbox Vault to avoid exposing my personal vault names.
Obsidian 1.13.4 — Settings navigation lag:
Obsidian 1.12.7 — same interactions:
Obsidian 1.13.4 — Vault management menu:
Obsidian 1.12.7 — same menu:
3. Computer specifications
Original PC:
Windows 11
16 GB RAM
Additional test environment:
Microsoft Hyper-V, Generation 2
Windows Enterprise Evaluation
2 virtual CPUs
Approximately 2.5 GB RAM allocated to the guest OS
Hyper-V virtual graphics adapter
The issue was reproduced in both environments. Obsidian 1.12.7 was noticeably more responsive under comparable test conditions.
We are at version 1.14.5 public. Not sure why you haven’t tested that.
I can’t reproduce what you are describing. How do you usually run obsidian? Inside hyperv on or bare metal? In the latter case, what are the computer specs exacly?
The lack of on hover highlight in the vault management menu is a separate bug.
What does version 1.14.5 have to do with this? I’m reporting a specific issue in version 1.13.4, which does not occur in 1.12.7. I’m not asking you to fix an older version.
You asked me to provide a screen recording in a clean Windows environment. That’s exactly what I did.
I normally run Obsidian directly on my Windows PC, not in Hyper-V. I used Hyper-V specifically to demonstrate that the issue in 1.13.4 persists in a separate, clean Windows installation, without my original user environment.
As for the hover highlighting, I never claimed it had the same root cause. I simply documented another issue observed in 1.13.4.
Please read my previous message more carefully. I’m providing the evidence you requested.
