Slight offset of preview-popups
I’d like the popups to pop up a few (~3-5) pixels to the right (or left) of the mouse cursor.
I have many tables with things, and I like to make use of the mouse-over popups to get the data density up.
This helps with tables - it allows me to just move the mouse cursor down to get a rapid succession of different popups, one for each line.
Right now, this requires a little mouse dance every time:
Note that the popup covers the table content almost perfectly.
This is actually possible via CSS. E.g., add the following to your snippets and play with the values.
.popover.hover-popover {
    margin-top: 5rem;
    margin-left: 5rem;
You may have to increase the width and height values of .popover.hover-popover to keep the size of the popover large enough for your purposes.
    margin: 3px;
That’s pretty awesome. Margin to 3px seems quite enough for me.
I think it would help if it’s a default, it’s not taking much space and makes the experience that much easier. (sometime the popup is above, or to the left, so margin seems like the right thing to use).
