When doing a quick slide presentation using Obsidian, there is no easy way to use vertical slides.
Using <section> somehow helps, but is clunky and doesn’t interpret Markdown.
It seems data-separator-vertical isn’t defined in the embedded reveal.js.
Would it be possible to define a “markdowny” vertical slide separator? Maybe *** or +++ or even ---- or the like?
So we could use slides like …
## Slide 2
## Slide 2.1
## Slide 2.2
## Slide 3
where “Slide 2.1” and “Slide 2.2” are vertical slides below “Slide 2” and “Slide 3” is the next horizontal slide?
I think *** should be preferred over +++, since it also produces a <hr> when used in normal preview.
None that really functions.
