Disclaimer
Is this plugin open source? Yes!
Is this plugin completely free? Yes!
Is this plugin vibe-coded beyond the author’s ability to comprehend how it works? No, it is not vibe-coded at all!
Community Directory: https://community.obsidian.md/plugins/simple-vault-statistics
This plugin adds a simple popup with statistics about the current vault. All the other “vault statistics” plugins are too complicated for my taste, so I made this plugin with a minimalist interface and backend.
Customizing
Here are all the settings available in this plugin. You can choose which statistics are shown and the style they are shown in. You can also choose to treat .txt files as notes.
Here’s what the different display styles look like:
You may edit any of the plugin’s settings while the statistics popup is open. Doing so will update the popup.
Hi
I would love to see the statistics this plugin surfaces for you. It makes me happy to see people use the thing I made, and I find it really interesting to quantitatively compare how different people use Obsidian.
Btw, I put a lot of effort into optimizing the algorithms for computing the statistics. If you have a really big vault I am interested to hear how well the plugin handles it :)
