After banging my head against this for a while I realised there’s no native way to drag‑resize two side‑by‑side panes on iPadOS. Even with a mouse the hover‑based handle won’t budge, and every thread I found either trailed off or concluded with “works on desktop only”.
So I tried a CSS workaround—and it does the job. I use it to read and annotate PDFs (the pdf on the left pane, the notes on the right pane).
1 · How it works
Obsidian lays out panes with Flexbox. Each pane’s .workspace-tabs
element carries an inline flex-grow: 50
, which keeps them locked at 50/50. A snippet that forces different flex-grow
values (with !important
) lets you pre‑set any ratio you like.
2 · Minimal 60 / 40 snippet
/* 60 / 40 split on any iPad (tactile or with mouse) */
@media (min-width: 768px) { /* avoids iPhone */
.is-mobile
.workspace-split.mod-root
> .workspace-tabs:nth-of-type(1) {
flex: 3 1 0 !important; /* ≈60 % */
.is-mobile
> .workspace-tabs:nth-of-type(2) {
flex: 2 1 0 !important; /* ≈40 % */
Put that file in .obsidian/snippets/
, enable it, reload UI, and the first pane now takes ~60 % of the width while the second gets ~40 %. Disable the snippet and you’re back to 50/50.
3 · Toggling with a hotkey
Install Snippet Commands (Community Plugins). It registers a “Toggle snippet: <name>” command for every CSS file in your snippets folder.
Assign a hotkey (Settings → Hotkeys) and you can switch the 60 / 40 layout on or off instantly.
4 · Multiple ratios
Nothing stops you from keeping several snippets—split‑70‑30.css
, split‑80‑20.css
, etc.—each with its own hotkey. Instant layout presets, no drag handle required.
