If you have multiple Sidebar Tabs (left or right sidebar) and you select a different sidebar tab then the one Obsdian opened with, after a restart of the app the newly selected sidebar tab is not remembered. Only by collapsing and reopening the sidebars the newly selected tab is remembered after reload.
Here is an example:
I used the reload command to show the behaviour on restart. The same happens after a regular close and start of the app.
I used version 1.5.11 (Installer version on Linux .deb file, Pop OS 22.04)
