We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
- Open one pane with links. Open a right side pane from a link with option-command.
Subsequent opening of links will open the link in the right side opened menu (before 1.0.3 this happened even without option-command which is expected), but at least with command-option.
command or option-command links will open up a new pane, resulting in multiple panes being opened and constant need to close those.
- Operating system:
- Debug info:
Obsidian version: v1.0.3
Installer version: v1.0.3
Operating system: Darwin Kernel Version 21.6.0: Mon Aug 22 20:19:52 PDT 2022; root:xnu-8020.140.49~2/RELEASE_ARM64_T6000 21.6.0
Live preview: off
Legacy editor: off
Base theme: light
Community theme: Atom-ks
Snippets enabled: 1
Plugins installed: 4
Plugins enabled: 4
1: Text Format v1.8.1
2: Smart Random Note v0.2.1
3: Vault Statistics v0.1.2
4: Collapse All v1.5.3
Please fix this, it’s been a workflow for me since the very first Obsidian versions before even the pane system. It’s a necessary workflow when working with two documents at the same time.
