Showing incomplete tasks using Dataview in Minimal theme
I use Kepano’s minimal theme in my Obsidian and use dataview to see all pending tasks from my daily journals.
The following code helps me do that.
TASK
FROM "journal/daily"
WHERE !completed AND regexmatch("^2025", file.name)
GROUP BY file.link
SORT rows.file.ctime DESC
LIMIT 10
This gives me the latest tasks that are not completed yet.
The minimal think allows checklist of various kinds. For instance, I can use these and more:
- [ ]	to-do
- [/]	incomplete
- [x]	done
- [-]	canceled
- [>]	forwarded
I particularly like [-] version that lets me see a planned task that is not finished but is off the list. It should not popup up when I use my dataview query to see tasks to do which is not the same as tasks remaining.
There are tasks that are remaining but are no longer relevant. Or I at times, wish to use other completed types of checklist as shown in the above examples to show importance of task or celebrate when it is done using a Star instead of regular checkmark.
Is there anyway, I can only consider [ ] as empty and all others as completed?
I don’t know how to address this issue. So, I have not tried many things.
TIA.
In your WHERE command, change !completed to !checked.
(Info about implicit fields for tasks: Metadata on Tasks and Lists - Dataview)
You can also filter by status. E.g.,
WHERE (status = ">" OR status = "/") AND regexmatch("^2025", file.name)
… to see your tasks that are marked incomplete or forwarded.
Using checked do indeed check whether you’re using any custom status other than the space characters. However, I’m using a similar scheme, and then all of these indicate a task not being completed; [ ], [/], [\] (and if feeling frisky also [¿], [¡], [+]). And I count the following as completed: [x], [>], [<], [-].
To properly check for these I use variations over the theme of:
WHERE contains(list(" ", "/", "\", "¿", "¡", "+"), status)
Or either !contains(...) or similar lists for the completed variants.
