Consider the following note:
## Full Embed: Path Available
![[Embedded-Note-Filepath]]
## Embed/Transclude Block: Link Path Missing
![[Embedded-Note-Filepath#This is a Heading]]
while results in:
In the first case, the embed path is visible. In the second the path is not.
It would be good to have at least some information available for block transcludes/embeds. Right now, even on hover there is no information available, and showing/hiding the CSS selector .embed-title
has no effect.
Without this information, the only way to figure out what the file behind the transclude is to click the link and go to the file. This can be very disuptive.
The link info is exposed as the embed title for block embeds.
None to provide the information in-situ,
