"Show context menu under cursor" command does not work in a popout window
  1. Open Sandbox vault
  2. Open two tabs, each containing a note
  3. Move of the tabs to a pop-out window
  4. In the pop-out window, in editing mode, press the assigned shortcut, or use the command Show context menu under cursor
The context menu to show up under the cursor in the pop-out window
The context menu shows up in the note in the main obsidian window. Or it doesn’t show anywhere at all.
  • Debug info:
	Obsidian version: v1.0.3
	Installer version: v1.0.0
	Operating system: Windows 10 Enterprise 10.0.19044
	Legacy editor: off
	Plugins installed: 0
	Plugins enabled: 0
Right-clicking on the note works perfectly well.
thanks
will be fixed 1.1
