Currently when using [[path/file]] to create a file (in order to save myself from having to use the mouse to make sure that my new file goes in the right folder), the file gets created correctly but retains the visible name [[path/file]] even if I have the option to display shortest path checked. This is visually distracting because the other links in the file aren’t as long and have a different structure, but it’s not, like, a crisis or anything.
Ideally, the file would get created, and then the filename on the original note would revert to [[file]] instead of [[path/file]] as appropriate.
Apparently this is difficult to do because reasons, but Licat said to file the FR so he remembers to noodle over it and try to come up with a solution to the problem of having a “navigate” and “edit” behavior at the same time.
My current workaround is to just not use this (otherwise awesome) feature.
