Searching help documents and forum
Searching hotkeys in Obsidian options
I would like to insert the file name into my note as plain text (not a wiki-style link) using a quick keyboard command. Is there a way to do this?
Current Workaround
Defined a one element template “File Name” in the Templater Plugin with {{tp_title}}, which I can then insert using the Templater hotkey and choosing the “File Name” template.
Using the Templater plugin was going to be my suggestion. There’s no built-in way of doing it, and that plugin does so much more that I think it’s your best choice.
