Hello,
I started to use intensively Obsidian and falling more and more in love with it. And the addition of the Obsidian android app + sync service… Great !
Currently, I am starting to implement kinda todo list of the notes I have to work on.
So on each note, I create a todo line like this :
Is there a way to get the my note title automatically entered with a keyboard shortcut ?
Thanks
Yes, you can do this @szdavid
install 2 community plugins:
- Templater
- Hotkeys for templates
Then, make a note in your templates folder that has just this content:
- [ ] <% tp.file.title %>
Assign that to a hotkey… voila
Thanks for this great tip. It looks fine in preview mode, but I get this in edit mode:
- Workbench
Any idea what is causing the slashes?
Can you screenshot it? I don’t see any slashes
The top line shows the slashes. Thanks for offering to help.
hmm… that’s really odd. Just checking- is this how you’re set up?
a template called e.g. “note title template” :
then edit a note and trigger your hotkey:
If you copy/paste from the forum, it actuallyadd slashes and you have to remove them
Dangit, I mean, thank you. You are, of course, right. I had copy/pasted. You are appreciated.
