I’m used to pressing Ctrl-0 in most of my text writing applications to make the current pargraph as default. If that doesn’t work, usually pressing the shortcut key for a paragraph level (e.g. H1) toggles between default and H1 levels.
Is there a way to do this in Obsidian? I can’t find that in the list of hotkeys and I seem to be the only one who’s wondering.
Searching the hotkeys list, pressing Ctrl-1, Ctrl-0, etc. Before I make a feature request, I want to make sure I’m not missing something.
