Shortcut-Icon for Core Plugins "Unique note creator" and "Random note" is missing
Reproduced in sandbox vault.
I
Open options → core plugins
activate “Unique note creator” or “Random note”
the Shortcut-Icon will not appear, although there are commands that are connected to these plugins.
I know that it is possible to do this also via shortcuts directly, but the Shortcut-Icon is nice and as it’s only not working for these 2 plugins, I assume that’s not what was intended.
Yes, reproduced in Sandbox vault
The Shortcut-Icon (“Plus”) next to the plugin
No Shortcut Icon
Obsidian version: v1.8.9
Installer version: v1.8.4
Language: de
Catalyst license: supporter
Insider build toggle: on
(Note: also checked it with language: en)
works for me.
Perhaps you just disabled the buttons (right click on the bar)
I think, they were talking about the “+” icon appearing on the right of some Core plugins (once enabled in the Core plugins menu) allowing to customize/add hotkeys for said plugins :blush:
ok thanks for clarifying!
