I added a Toggle Readable line length plugin to be a targeted solution to this problem. It works the same way as some of the other plugins mentioned above, but doesn’t do anything except add this toggle (command and hotkey).
Thank you so much. Works perfectly.
Made this account specifically to ask for this feature. There are so many useful settings we can bind to hotkeys, but this one is missing.
Enabling or disabling the “Readable Line Length”-setting via a hotkey
Add option to set a hotkey for the “Readable Line Length”-setting
Set it via the settings → editor → display → “Readable Line Length”-toggle
I want to be able to toggle the Readable line length feature without using a mouse/pointer from the command palette or using a custom keyboard shortcut.
Add Readable line length as a command in the command palette (Ctrl+P).
None
None
There are some options:
Create a CSS snippet to define a width and set it to a hotkey using:
a command will be added 1.9.8. No ETAs
