I have just bought a year of Obsidian Sync and am running into problems with settings syncing.
Ex: working vault on my iMac and synced to Obsidian Sync. I have all of the options turned on to basically sync everything including all settings.
Set up new vault via open vault from Obsidian Sync into a new folder on my MacBook Pro.
Vault syncs but all of the non-default options that I turned on in the vault on my iMac aren’t turned on here. Also the appearance is set to dark instead of light (which is what I have set on my iMac). These settings seem to then overwrite what I had on my iMac, including folders for attachments, where to create new notes, etc.
Not sure if I did something wrong here or there is a bug in Sync. Any ideas?
Thanks!
