Setting base color Light is not applied to the top android status bar at startup
After a recent update (unfortunately i can’t say exactly which, but I think the June 25 one), it seems that the status bar at the top does not adjust to a white background anymore when opening the app - which is a slightly less clean look imo.
More Info
Phone: Google Pixel 4a
Android Version: 13
this will be fixed in version 1.7. No ETA.
