Setting a notes property to output of a script/plugin
I’m using the weather fetcher plugin and want to add the current weather to a property in my daily note.
At the moment I’m adding as inline text in the template with
<% app.commands.executeCommandById("weather-fetcher:weather-insert") %>
and this does work fine, but I think a property will be cleaner, and can also be used in the new basis functionality.
I’ve tried creating a new property
weather : <% app.commands.executeCommandById(“weather-fetcher:weather-insert”) %>
<% weather %> : <% set weather = app.commands.executeCommandById(“weather-fetcher:weather-insert”) %>
and even
<% weather %> : <% set weather = await app.commands.executeCommandById(“weather-fetcher:weather-insert”) %>
But the property is always empty
