Let’s say I have a file with this title: tips to visit a new location
If in the search bar I write: file:(tip country) I won’t find the file
So I decided to add in the property aliases the following words: country place city
Unfortunately file: searches only on the title, while I would like to search both on title and aliases.
I tried some weird combinations of commands like (file: OR ["aliases":])(tip country) but they don’t work
Is there any way to search in both title and aliases? Is there any better alternative than using aliases?
As an alternative I thought to write the title as: tips to visit a new location (country, place, city) but that would be a mess if I do it for every note.
I wonder if it is just the way you typed the syntax? I don’t see that pattern of splitting the brackets like that in the help docs. This test worked for me for a note with an alias “Valles Marineris”
[aliases:Valles Marineris]
file:Mars OR [aliases:Valles Marineris]
Or a partial search of an alias:
[aliases:Valles]
[aliases:V]
or using quotes to make it exact (or exact partial):
Thank you for the answer. I think that for now I would structure my file like this:
aliases: tips to visit a new (country place city)
In case I want to search for it and the words that come to my mind are tip country I would write in the search bar: [aliases:tip country] OR file:(tip country)
Anyway I would still like to have the possibility to search in both aliases and title without having to write a poem everytime.
The Quick Switcher allows to do so but the words order matters and for this reason it is unreliable. For example if I write in the Quick Switcher tip country it would find the file but if I write country tip it won’t find the file
