Search for tags with icons/emoticons out of frontmatter/yaml does not work
  • Create a new page
  • Add via YAML a tag, like:
    • tags: [:date:/2022/04/15]
  • Activate the “Reading view”.
  • Press the tag to prefill the search text-field.
“tag:#:date:/2022/04/15” is copied into the seach-textfield
“tag:#/2022/04/15” is copied into the search-textfield
  • Debug info:
    Obsidian version: v0.14.2
    Installer version: v0.13.31
    Operating system: Windows 10 Enterprise 10.0.19044
    Catalyst license: none
    Legacy editor: off
    Base theme: light
    Snippets enabled: 2
    Safe mode: off
    Plugins installed: 17
    Plugins enabled: 17
Works in the help vault (no plugins or themes) to copy the icon to the search field, but the tag itself is read as a series of nested tags because forward slashes are used for nesting:
Angel
Hmm ok thanks, I especially tried to disable all my plugins, but I think I forgot to restart Obsidian. I will try to find which plugin could be responsible. Thank you!
If I disable the “Twitter emoji” flag from the “Emoji Toolbar” it seems to work everything as expected.
@Angel Thank you again for the hint.
Pleasure.
Angel
