No worries. ![]()
I worked out that I’m probably better off filing bug reports over at Github, so I’ve done that.
No worries. ![]()
Yep, that’s probably the best course of action ![]()
Yeah, there might be some things that don’t work that well in macOS, since CSS feature support on macOS happens through the Safari Browser engine, unlike Linux/Windows, where it uses Chrome. Since most of the current scrollbar code is directly targetting chrome features, there’s a possibility of Safari not rendering it correctly. I’ll look up the documentation and see what’s needed to properly target Safari. ![]()
Dw, I’ll fix it soon! ![]()
As for the other wikilink-related issue, if you haven’t already, be sure to submit an issue on github, as I get notified and can see it more easily.
Thanks! I’ve gone ahead and created issues over on Github. Thanks for your efforts!
Any plans to add asides as callouts? I think ITS does that + you already have the styles for it
Maybe in the future, yeah. Just need to get around to fixing some issues first.
Sanctum for Obsidian v0.15.9
Here are the latest changes to Sanctum! Some of them you might have already noticed if you have updated recently, but there are also a few new ones, especially bug fixes.
Thanks for the brilliant theme, I’ve seen that the aesthetics has changed a lot in the theme, I’ve actually liked the old headings a lot, the thinner and a bit wider heading? I’ve seen it in earlier versions, may I ask what font is that and the weight of it? Here is a picture that is shown before in this forum that is using that font!
Ooh may I ask if the block quote feature is completely deprecated?
I’ve tried it but didn’t work. The normal > text here
Quote feature just made minimal changes and made the text a bit smaller, is it how it is supposed to work? I found it changed drastically compared to early showcases!
