So I’ve got this (rather old) Raspberry Pi Model 2B, which is only capable, as far as I know, to run a 32bit OS which if I’ve understood stuff correctly means it can’t run Obsidian natively on it. So the first question is Is it true it can’t run Obsidian on the Raspberry Pi OS 32bit?
Then I started thinking that it does indeed run X11, it seems, and I do have a Mac Mini which is capable of running Obsidian, so the second question is Could I either run some virtual display thingy, or X11 session, or similar, and run Obsidian from my Mac on my raspberry Pi?, and if so Do you have any hints on how to do so?
