I use two language for my notes, English and Persian (Arabic). Each individual note would be either in English or Persian (not both).
Using iOS, I want to see my English note with the left-to-right format and see my Persian notes using Right-to-Left format.
Under Editor Setting, on Obsidian ios, I turn on RTL setting. However, when I do so, my English notes are also become RTL which is what I don’t want.
Is there anyway, or any plugging, allowing me to use both LTR and RTL with English and Persian notes respectively?
There are two plugins here that may do what you want:
https://github.com/esm7/obsidian-rtl
https://github.com/mwxgaf/obsidian-dynamic-rtl
You could also use a cssclass and some CSS to make certain notes RTL if your Obsidian settings are the default LTR. In your note, at the top, where you want RTL:
cssclass: rtl
and the CSS:
.markdown-source-view.rtl .cm-editor, .view-content.rtl {
direction: rtl;
How to use CSS snippets if you aren’t familiar:
Amazing! Thanks, both plug-ins work great and solved my issue!
system
Closed
September 18, 2023, 12:29am
4
